Help Removing Rear Backseat Windows
Old Apr 27, 2010 | 05:55 PM
jpsycoboy5's Avatar
jpsycoboy5
Default Help Removing Rear Backseat Windows
I need help on how to remove the little back windows not the sliding but the little fold ones with the latch i know how to get the latch off but how do you get it off the truck the rest of the way
Old Apr 27, 2010 | 09:37 PM
kissmymagnum's Avatar
kissmymagnum
I am almost sure that the hinges just come off the front of the window and are screwed to the front edge of the rear doors... I remember looking at them before on mine but never paid a lot of attention at how to get them off, although I am fairly sure that is all that holds them after you remove the latch.
Old Apr 28, 2010 | 06:29 AM
jpsycoboy5's Avatar
jpsycoboy5
I got the latch off the one at the rear of the window I can't get it off from the right by the drivers door. Is there something behind the weather strip to take off?
Old Apr 28, 2010 | 08:32 AM
2k10HemiRam's Avatar
2k10HemiRam
Sorry, I tried to find out in my Chiltons book but it says that all fixed windows should only be removed/replaced by professionals so it gives no directions on the replacement of any of our windows but the front driver/passenger.
Old Apr 28, 2010 | 08:44 AM
Flue's Avatar
Flue
per the pdf manual found in the DIY section...and Chilton SUCKS!
(1) Remove cargo door trim panel (Refer to 23 -
BODY/DOOR - CARGO/TRIM PANEL - REMOVAL).
(2) Remove the screws attaching the latch to the
cargo door (Fig. 19).
(3) Remove the bolts attaching the vent glass to
the cargo door (Fig. 20).
(4) Remove the glass from the door.
(5) If necessary, remove the latch from the glass.
Old Apr 29, 2010 | 06:33 AM
jpsycoboy5's Avatar
jpsycoboy5
Thanks a lot everyone I'll try it out tonight
