need some help guys
Old May 1, 2010 | 01:06 PM
gevalco207's Avatar
gevalco207
Default need some help guys
ok got my new superchip 3517 by the way thank you eric99 i really like it, it really woke my truck up, but check engine light came on within 15miles throwin codes p0300,p0302,p0307, my truck before i got the chip didn't idle 100percent very slight miss at idle i was thinking coil, but please let me know what you think
Old May 1, 2010 | 02:55 PM
Old Dodge 1's Avatar
Old Dodge 1
SYMPTOM
P0307 - CYLINDER # 7 MISFIRE
TEST NOTE
This symptom is diagnosed using the test P0300-MULTIPLE CYLINDER MISFIRE.
WHEN MONITORED
Any time the engine is running, and the adaptive numerator has been successfully updated.
SET CONDITION
When more than a 2 % (1.5 % LEV) misfire rate is measured during two trips (one trip California), or with a 10 % to 30 % misfire rate during one trip.
POSSIBLE CAUSES
•Engine mechanical problem
•Erratic CAM/CRANK sensor signals
•Fuel system problem
•Misfire conditions no longer exist
•Other possible causes for misfire
•Secondary ignition or mechanical problem
Old May 2, 2010 | 01:14 PM
dhvaughan's Avatar
dhvaughan
hmm, 2 different misfires. i'd reset pcm and monitor it.
i suspect you've had your foot in it a lot ?
is your last tuneup fairly recent or not.
Old May 5, 2010 | 08:22 PM
gevalco207's Avatar
gevalco207
Yes i have had my foot in it lol. tuneup 4000 mile ago.
