Need Help Removing Upper Ball Joint 1995 Ram 1500 2wd
Old May 2, 2010 | 09:28 AM
isadream's Avatar
isadream
Default Need Help Removing Upper Ball Joint 1995 Ram 1500 2wd
We have a 1995 ram 1500 2wd and we need new balljoints. Ball joint press is too small to fit on the upper ball joints to remove them so any suggestions on how to remove the upper ball joints on this truck?
Thanks,
Rick
Old May 2, 2010 | 09:52 AM
95RAM360's Avatar
95RAM360
torch and a ball joint press.....rent a bigger one.
took ALOT of heat, pounding, and pressing, and mine finally budged....try map gas...this stuff does wonders
Old May 2, 2010 | 11:23 AM
dhvaughan's Avatar
dhvaughan
no personal experience, but i've read that Advance Auto has the best ball joint press for rent.
Old May 2, 2010 | 01:37 PM
isadream's Avatar
isadream
Ok thanks I will call them--I was shocked that ball joint press was too small. They said it was the one for the my truck.
Thanks,
Rick
Old May 2, 2010 | 02:10 PM
dodgeram07's Avatar
dodgeram07
+1 on Advance
https://dodgeforum.com/forum/2nd-gen...placement.html
Old May 3, 2010 | 04:00 AM
isadream's Avatar
isadream
Smile Thanks!!!
THank you to everyone!!!! Once side of the truck is done--ran of time on the other side. I could not have done this without your help!
Rick
