Ac blowing out of defrost vents, not where they should be??
Were working, flipped the switch one day, weird noise and bam. Blows ice cold but not out of my vents. if you switch to heat it blows from floor i believe but will have to double check. any ideas? Searched but didn't really know what to search for so I came up empty!
wildvents. sorta sounds like them but then again its sounds like a blendor or something else
im sure there will be someone chiming in shortly, seems like a common problem
looks like you gotts vac.leak just checkall your vac. lines i just replaced some of mine and it went back to normal after that and mite be plenum or what he said
