only 35 psi fuel pressure.
Old May 8, 2010 | 09:20 PM
1994ram1500's Avatar
1994ram1500
Default only 35 psi fuel pressure.
so earlier today i was taking a load to the city dump and my truck started acting really funny, sputtering, lackof fuel, etc. so i filled it up and it seamed to run fine afterwards. i went by autozone and rented a fuel pressure guage and hooked it up, only 35 psi pressure, should be 50? truck has 175000 miles so im thinking its time to replace the fuel pump? i think this is the culprit to my truck acting up this morning and also the underwelming amount of power it has had since i bought it. does this sound like a fuel pump problem? Also is there anywhere to get a good rebuilt fuel pump?
Old May 8, 2010 | 09:39 PM
UnregisteredUser's Avatar
UnregisteredUser
It could also be the fuel filter. But were it mine to do on a truck more than ten years old I'd replace both while the tank is on the ground so I'd not have to think about them again for quite a long time.
Old May 8, 2010 | 09:45 PM
1994ram1500
yeah, i guess ill just bite the bullet and pay the 180 the parts store wants for a pump, lol.
Old May 9, 2010 | 08:32 AM
dhvaughan's Avatar
dhvaughan
35 is low. i don't know how low you can go before you have insufficient pressure, but i'd bet your on the borderline and with a little fluctuation, you drop too low.
Old May 9, 2010 | 03:13 PM
1994ram1500
well it was at 35 psi when the truck was running "good" i couldnt get it to sputter when i had teh guage installed (of course) but i am thinking that it fluctuates a little and when it drops is when i have issues.
Old May 9, 2010 | 04:22 PM
aim4squirrels's Avatar
aim4squirrels
35psi *might* be fine for idle, it definitely won't be for anything beyond about 2000rpm.
My guess is the regulator has failed. Just replace the whole pump and be done with it.
I recommend the delphi pump over the airtex.
Old May 9, 2010 | 07:47 PM
sit22 II's Avatar
sit22 II
if u want u can just get the fuel pump from here
http://www.onlyfuelpumps.com/oem-rep...p-hfp-379.html
someone made a write up here about this pumps and it went great.
To bad i found this after i paid 250 for a new unit
Old May 9, 2010 | 07:54 PM
1994ram1500
can i get at the built in filters on teh module to clean them?
Old May 9, 2010 | 10:30 PM
1994ram1500
also, is there a way i can bypass the oem pressure regulator and put an adustable pressure regulator on right on the fuel rail?
Old May 9, 2010 | 11:09 PM
PurplDodge's Avatar
PurplDodge
39 PSI is the norm for a 1994.
