Rear end issues
Old May 16, 2010 | 09:22 AM
thebigbird's Avatar
thebigbird
Default Rear end issues
Does anyone know how difficult it would be to reseat the axle in a '94 ram 2500?
Old May 16, 2010 | 09:47 AM
Sheriff420's Avatar
Sheriff420
Do you mean connecting it to the truck? It lines itself up when you tighten the u-bolts.
Old May 17, 2010 | 02:34 PM
thebigbird's Avatar
thebigbird
No the C-clip that holds my axle in the differential is gone and i need to install a new one. i am having difficulties trying to acquire the C-clip as well as figuring out how to install it.
Old May 17, 2010 | 02:48 PM
CPTAFW163's Avatar
CPTAFW163
get c-clip eliminators.
Old May 17, 2010 | 02:51 PM
94Beater's Avatar
94Beater
C-clips I could only get at the dealer. I just got set of 2 when rebuilding my axle. About 10 bucks. As far as replacing it - easy. Just get 3 fresh quarts of gear lube. Once you take the cover off. Pull the cross pin out and push in the axles. C-clips usually fall out then. Just install set of new ones pull the axles out. Install cross pin and your done.
Diff takes 2.3 quarts of 75W90.
Hope this helps
