front axle nut size
Old May 16, 2010 | 02:39 PM
junkyarddogfan's Avatar
junkyarddogfan
Default front axle nut size
hello;
i keep reading posts on here where all say the front axle nut is 1 11/16...i have a '97 4X4 1/2T and yesterday i bought a 1 11/16 socket from sears and low and behold, its a sniffle too small...i bought a 1 3/4 and it fits but loosely, a sniffle too big, if you will...i assume its some sort of metric nut, but no way would the 1 11/16 fit it...am i missing something here..and if it is metric, does anyone know what size so i can stop a snap on man and buy one?
thanks.
Old May 16, 2010 | 02:43 PM
004x41500's Avatar
004x41500
Originally Posted by junkyarddogfan
hello;
thanks.
if its a metric, i think its a 36MM
Old May 16, 2010 | 03:14 PM
Pete379's Avatar
Pete379
if you got a dial calliper measure the 1 11/16th according to the conversion deal i just used it's a 43 or something pretty close. unfortunately you can't find them I looked and looked and couldn't find one. honestly I'd go with the 1 3/4 and see if that'll work if not bout the only other thing you can do is beat the 1 11/16 on there. it's not a good thing to do but if it comes to it you might have to. a chrysler dealership might have one you could borrow right quick to break it loose and then put the cotter key back in it so you can get it home.
Old May 16, 2010 | 03:15 PM
VEETEN's Avatar
VEETEN
43mm
But maybe a cheaper 1 11/16 would fit
Is it a 6 point you got or a 12 point,
Old May 16, 2010 | 03:33 PM
95RAM360's Avatar
95RAM360
thats odd, i got my 1 11/16 from sears as well, and i had no problem...try a little bit more,keep spinning it little by little until it slides on. I bet it will fit.
Old May 16, 2010 | 04:58 PM
junkyarddogfan
i'll give it a shot again, but i spun it like 5 times and it wouldn't go...the 1 3/4 would but again, with some play...appreciate the 43mm part...36 is way too small...
thanks
Old May 16, 2010 | 05:01 PM
004x41500's Avatar
004x41500
thanks
well you know, i just guessed lol. hopefully things will work out for you
Old May 16, 2010 | 07:17 PM
VEETEN's Avatar
VEETEN
i'd try to tap the 1 11/16" on.. it's only .005" smaller than the 43mm, It should fit.
all sockets have slop in them, 12 points have more wiggle room though.
I used the 1 3/4" cause I couldn't find a place local that had anything else.
Old May 16, 2010 | 07:24 PM
004x41500's Avatar
004x41500
when i did mine, i had to borrow it form the local home depot.
Old May 16, 2010 | 09:52 PM
pavement_hater's Avatar
pavement_hater
I had to turn and wiggle mine a little bit. Its a tight fit.
