Help,I need trans. tech. info
Old May 22, 2010 | 07:25 PM
PistonPete123's Avatar
PistonPete123
Default Help,I need trans. tech. info
I have a 97 5.2 v-8 but only a 3 speed trans ( from a ram van) I need the resistance value for the tourqe converter lockup solenoid and the o/d solenoid, and any info on a couple other codes I have (753) shift solenoid, (713) trans temp. (492) secondary air bank 2. I have a project that i'm working on and i'm not using the same trans so i need to trick the comp.
