more power at higher rpm
Old Jun 5, 2010 | 09:12 PM
pentec's Avatar
pentec
Default more power at higher rpm
My 98 Ram 1500 2wd seems to get a real puch of power at higher rpm. When I say higher I mean about 2,750 and up. A friend of mine said that there may be a plenum leak. I have looked in the throttle body and intake and see no oil there, I use less than a quart of oil between oil changes approx. every 3,000 - 3,500 miles never have any kind of troubles at all. It just seems wierd that a 360 would have more high rpm power. Am I over looking something here? Is there anything else that I should be looking at or checking? Or is this normal for this engine? Thanks in advace for all of your comments and help.
Old Jun 5, 2010 | 09:16 PM
J415's Avatar
J415
99% sure your belly pan (plenum) is leaking.
Old Jun 5, 2010 | 09:30 PM
lastrights's Avatar
lastrights
clogged cat also
Old Jun 6, 2010 | 12:10 AM
Hammer Down's Avatar
Hammer Down
It doesn't sound like there's anything wrong with the cat. That would kill top-end power.
I didn't see any oil in my intake until I got the pan off.
Also, my truck has a similar power curve. Do you have an aftermarked exhaust? If it is too large, it can move the power curve up.
Old Jun 6, 2010 | 12:47 AM
d_edge's Avatar
d_edge
I seem to have the same issue, always thought it was weird, hopefully somebody can shed some light.
Old Jun 6, 2010 | 01:02 AM
J415's Avatar
J415
A clogged cat will cause a misfire and top end loss like Hammer Down stated.
Old Jun 6, 2010 | 09:12 AM
95RAM360's Avatar
95RAM360
your plenums leaking...
Old Jun 6, 2010 | 09:36 AM
pentec's Avatar
pentec
I have been plannning to get an after market exhaust here sometime soon. I had to have the muffler and tail pipe replaced early this year for emissions purposes. I was running a single in dual out Flowmaster but didn't have the cash to have that setup put back on so it is stock again. Even with that Flowmaster exhaust I still noticed the power difference.
Old Jun 6, 2010 | 02:59 PM
ramsport-99's Avatar
ramsport-99
My truck has the same issue, It also didnt show any other sign of the plenum until last thursday night when I was racing my brothers lancer, a friends jetta, and another friends 95 2500 5.9 with some minor mods. After loosing all three races because I cant get out of the hole I took off the intake hood and just with a cell phone saw the oil shining. The entire belly pan is covered with the brownish shine of oil. Basical what im trying to say is just because u dont see anything right now, doesnt mean that it isnt blown.
Old Jun 6, 2010 | 04:30 PM
dodgeram07's Avatar
dodgeram07
turbo
14x3 air cleaner,52mm tb,1.7roller rockers,headers,sct tune,heads,cam,air gap
you may have the death flash also
