Question on a part
Old Jun 6, 2010 | 05:38 PM
jpbalt's Avatar
jpbalt
Default Question on a part
What is the part bolted to the inner fender, under the battery? Mine has a broken vacuum line near it and I'm trying to find out if it should go to that.
Old Jun 6, 2010 | 05:41 PM
GeorgiaDodge's Avatar
GeorgiaDodge
should be the cruise control diaphragm if im not mistaken, Welcome to DF
Old Jun 6, 2010 | 06:13 PM
Maxx_Magnum's Avatar
Maxx_Magnum
yup I was gonna say cruise control as well... I bet your cruise isn't working, right?
Old Jun 6, 2010 | 09:48 PM
jpbalt's Avatar
jpbalt
I'll check that out tomorrow. I haven't used the cruise control in years. Thanks for the help.
Old Jun 6, 2010 | 09:57 PM
GeorgiaDodge
ive heard someone on here one time saying theyere battery had leaked acid on their cruise control and messed something up. but if its a vacuum should be fairly simple to fix?
Old Jun 7, 2010 | 09:44 AM
Sheriff420's Avatar
Sheriff420
Cruise control servo. You can buy a roll of vacuum line and I believe the parts stores carry the rubber elbows also. You could also use some rubber hose that is the correct diameter to squeeze over the plastic line to patch it. The common cause for that line breaking is battery acid dripping. Check the canister over to see if it has any holes melted in it.
