Got a package!!!!
Old Jun 9, 2010 | 01:39 PM
Veritas's Avatar
Veritas
that was probably one heavy package
Old Jun 9, 2010 | 01:50 PM
offroadjosh's Avatar
offroadjosh
^^^ thats what she said.... hahaha
and yea actually it was
Old Jun 9, 2010 | 02:06 PM
zje400ex's Avatar
zje400ex
When will you get the lift installed and some pics for us???
Old Jun 9, 2010 | 02:20 PM
offroadjosh
When i get the engine and t case outta the garage so i can pull my truck in :P, plus i have been hitting all the bolts with 50/50 acetone/atf and i also tap each one with the sledge to hopefully make the job easy (i dont have any rust on my truck so i should be fine....)
Old Jun 9, 2010 | 02:22 PM
lastrights's Avatar
lastrights
leave it on see how it looks , ram is going to look badass!!!
Old Jun 9, 2010 | 02:24 PM
zje400ex's Avatar
zje400ex
Good idea on hitting the bolts with that solution. I've heard that is the way to go when dealing with rusty bolts. When I put my lift on, rusty bolts caused the most problems. Sounds like you should be good to go. Good luck on the install and make sure to be safe
Old Jun 9, 2010 | 03:02 PM
offroadjosh
Thanks! Also good note on being safe! will be using jackstands!
Old Jun 9, 2010 | 03:18 PM
Fifthwheelin's Avatar
Fifthwheelin
Buy a pinstripe remover wheel at any auto parts store, its a rubber wheel that you mount on your highspeed air tool, and use that to remove the white from the raised letters. Wont hurt the tire at all.
Old Jun 9, 2010 | 03:37 PM
offroadjosh
hell i can use the one i did to debadge! thanks for the idea gunna go try it now!
Old Jun 9, 2010 | 04:13 PM
offroadjosh
Never mind lol doesn't work... the white is in the rubber itself(tried it on an old spare tire first)
