rims?
What year is your truck if its older than 00' you should be able to bolt on 15's without a problem if anything you might have to do a little grinding on the caliper, I put 15's on my truck for a quick test fit of some tires.
The advantage of going to a 15 inch rim is cheaper tires, and keeping the standard sizes instead of metric, if its 4x4 I would get 4.5 bs so you dont rub on the control arms maybe even a little less, 2wd you can get away with 5 bs
It would help if you added a sig with some info about your truck
my truck is 2001, so 15s wont fit? and they are 4" backspace. thats what im tryin to do is get the tires cheaper, im all bout savin money.
anyone know if 15s will fit on a 01 dodge ram 4x4?
ok well the other guy said only 00' and below would fit fine, but i dont understand that cuz i mean whats the difference between all other 2nd gen rams and a 01'? so i think they should fit also. thanks guys.
i have an 01 and when i went to buy new rims and tires at discount tire they said 15's wouldnt fit my truck so i got the 16's instead and just got some 285 rubber and judging by what i see on my rims 15's would more than likely not fit mine
