No safety hood latch-how to open
Old Jun 14, 2010 | 05:36 PM
a1handy's Avatar
a1handy
Default No safety hood latch-how to open
I recently purchased an 01 2500. When I tried to open the hood, the main latch activated but when I went to the hood the safety latch disconnected and came off. How can I open the hood without damaging or cutting a hole in the grill. What area of the grill should I try to reach the safety latch and how should I attempt to move it. Any help would be greatly appreciated
Old Jun 14, 2010 | 05:48 PM
Sheriff420's Avatar
Sheriff420
My sisters truck was locked one time and she thought the key was on the shroud so I had to get it for her. After some shroud banging and almost getting a pocket knife in my eye I decided to take the latch off to get the hood open.
If you look from under the truck you will see a bolt on each side of the latch.
With a really long extension (or a few of them) you can reach those two bolts with a socket.
After taking them out the hood will lift right up.
Then take a towel and press it down hard on the latch and pull the cable with some pliers and it'll pop out. That latch has a lot of tension, that's why you need a towel.
After opening the hood my sister decided it'd be a good idea to mess with it and that thing let go and shot into the hood. I almost peed a little.
Old Jun 14, 2010 | 07:20 PM
ghost4321's Avatar
ghost4321
IIRC the safety latch needs to be pushed to the passenger side to release. I'd look but mine is getting inspected.
Old Jun 14, 2010 | 10:05 PM
mrfarrell's Avatar
mrfarrell
it needs to be pushed towards the front of the truck...if you have long arms or a long screw driver i believe you can get it by going from under the front bumper you just have to push up where it would normally pin in
