What could cause high NOX, over 1K PPM?
Old Jun 15, 2010 | 03:14 AM
rich8329's Avatar
rich8329
Default What could cause high NOX, over 1K PPM?
My 96 ram failed California smog test. Failed with a high NOX output, all other readouts were normal. The truck has over 200k miles with a 2.5yr hi-flow cat. I am thinking that it might be EGR valve, but I don't see it on the emission decal. I can't seem to find it on the 5.9 engine, is it bolted directly to the cylinder head? Any photos would help.
Old Jun 15, 2010 | 03:26 AM
Ram_Me's Avatar
Ram_Me
1996s Don't have EGR valves. Neither of mine do.
Old Jun 15, 2010 | 03:38 AM
That1Dodge's Avatar
That1Dodge
It's usually a lean condition and there could be a number of reasons for it. Maybe a vacuum leak, bad O2 sensor, exhaust leak before the cat, EGR... anything that would make it run lean could cause high NOx. Unless I'm wrong.
Old Jun 15, 2010 | 07:16 AM
dhvaughan's Avatar
dhvaughan
no help, but an interesting graph.
according to them - high nox = lean.
http://www.3si.org/forum/f36/failed-...50/index3.html
Old Jun 15, 2010 | 10:19 AM
aim4squirrels's Avatar
aim4squirrels
There a 3 things I can think of that will help a lean condition/emission issues. I'll list them from cheapest to most expensive:
1. Try running a 1/4th tank of gas with a 20 gallon bottle of chevron techron concentrate plus, and run 2 treatments of seafoam or Mopar Combustion Chamber Cleaner. That'll clean your injectors and combustion chamber of excessive carbon and it'll burn cleaner.
2. Try to relocate the IAT sensor to a cooler location, or run a 180* T-stat, both should throw a bit more fuel into the mix, but keep you in emissions standards. This is honestly cheaper than suggestion 1, but requires a bit of wrench knowledge.
3. After all that, replace the forward O2 sensors. One of them could easily be reading false and causing a lean out condition. I believe the Cali emissions trucks have 3 forward O2 sensors, not sure if 1 or all 3 effect fuel trims. The sensors aren't very cheap, but you could probably replace all 3 for about the cost of a shop diagnosis and 1 sensor.
Old Jun 16, 2010 | 12:12 PM
rich8329's Avatar
rich8329
Thanks everyone for the sugestions. I only have has 2 O2 sensors. I did notice that the radiator does need to be flushed, this could be another problem.
