coolant leak?????
Old Jun 20, 2010 | 08:27 PM
dodgeman52's Avatar
dodgeman52
Default coolant leak?????
what would cause coolant to leak into the dust cover area of the trans mission. i know there is a drain so if the real main leaks it will leak out there but i have coolant around that area what could cause these?
Old Jun 20, 2010 | 08:39 PM
dodgeram07's Avatar
dodgeram07
rear freeze plug
Old Jun 20, 2010 | 09:17 PM
dodgeman52's Avatar
dodgeman52
do i have to take the trans out to do that? do u thing is odd to have this problem with the truck only having 61,500 miles on it?
Old Jun 21, 2010 | 01:23 AM
jasonw's Avatar
jasonw
Site Moderator
It may only have 61,500 miles on it, but its also 10 years old. Not common, but not unheard of.
Old Jun 21, 2010 | 11:27 AM
Augiedoggy's Avatar
Augiedoggy
yep very common actually...especially if tap water was ever used in radiator.. I have the same issue and used bars stop leak to slow the leak to a slow drip rather than pull tranny.
Old Jun 21, 2010 | 09:59 PM
dodgeman52's Avatar
dodgeman52
could it be coming out of the back of the intake? i would never put stop leak in my truck and seem that stuff do bad things. it seems like it only leaks when the truck is not running
