NEW timing chain whichone to get
Old Jun 20, 2010 | 11:16 PM
nathangfnd's Avatar
nathangfnd
Default NEW timing chain whichone to get
Should i get a 7 keyway timing chain or a 3 way timing chain
http://www.hughesengines.com/Index/p...1&partid=23310
or
http://www.hughesengines.com/Index/p...1&partid=23311
Is the 7 keyway worth the extra $$$$
Old Jun 20, 2010 | 11:49 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Screw that over inflated cost.
http://www.summitracing.com/search/M...d=timing+chain
Make sure to do the water pump while you are that far deep.
Old Jun 20, 2010 | 11:58 PM
dakotas ram's Avatar
dakotas ram
are you wanting that much adjustment for a reason?
Old Jun 21, 2010 | 12:20 AM
DodgeTech228's Avatar
DodgeTech228
You don't need an adjustable chain unless you plan to degree the cam while you're in there.
Old Jun 21, 2010 | 02:00 PM
aim4squirrels's Avatar
aim4squirrels
don't go cheap on the chain!
I did and had to replace it just 30,000 miles later.
Go JP Performance or Rollmaster. Some guys say the Mopar Performance double roller is a good chain, but the timing marks are hard to read on it.
I bought a JP chain and it's very solid, but a very tight fit on the crank. I had to hand sand the crank sprocket down a very little bit. The P/N is 5985 for that chain.
