Crank sensor
Old Jun 23, 2010 | 10:48 PM
junkyardjeff's Avatar
junkyardjeff
Default Crank sensor
I just put a trans in my girlfriends 98 and did not realize what that sensor was on the back of the motor,its running not so good now and was wondering if I should of removed the sensor before swapping trans and could I have damaged it. I am going to check for codes and it could have bad gas from sitting but how sensitive are those sensors to being banged on during a trans installation.
Old Jun 23, 2010 | 11:08 PM
aim4squirrels's Avatar
aim4squirrels
sensor is very easy to damage, but typically, if you do damage it the vehicle won't even crank.
Old Jun 23, 2010 | 11:33 PM
junkyardjeff
Probably some bad gas from sitting or the gas she put in after the trans installation is questionable,she got it from a station I got bad gas from so I will get some fuel treatment and see what happens.
Old Jun 23, 2010 | 11:51 PM
J415's Avatar
J415
Put some sea foam in the gas tank and see if that fixes it.
