This must be shared
Old Jun 25, 2010 | 07:49 PM
Skoubah's Avatar
Skoubah
i drive by one of those everyday, identical except a bit more rust.
I always wanted to see it out driving but its always just parked in the driveway.
Old Jun 25, 2010 | 07:53 PM
RM_Indy's Avatar
RM_Indy
Id say about at least 1/2 of the Indys came from the factory with a rollpan.
Of the 3 on the lot where I bought mine, 2 had pans. I bought one, good buddy I met a few years later online bought the other one with a pan.
I think I prefer my under hood, 1st pic is from 06
2nd & 3rd pic is how the motor looks now
Old Jun 25, 2010 | 08:18 PM
CPTAFW163's Avatar
CPTAFW163
^^ I remember when you first posted that first pic. You set the standard.
Are those powdercoated Valvecovers? Or are they anodized?
Old Jun 25, 2010 | 08:28 PM
RM_Indy's Avatar
RM_Indy
Powder coated, had a shop do them & my chrome diff cover back in 98, still look great.
Headers done by another shop, the Procharger head unit came polished.
I polished the tensioner, tb hat, ceramic painted or powder coated everything else myself(every bracket, nut, bolt & washer). Oh, my M1/4BBL(ported/decked/matched) is a specialty heat coating done by another shop, releases heat faster, has a heat reflective coating on the underside.
Old Jun 25, 2010 | 09:31 PM
RamSport97's Avatar
RamSport97
Alright, I'll say it, RM-Indy is a bastard . J/K Indy, I love everything about that darn truck.
Old Jun 25, 2010 | 10:11 PM
kj4cwa's Avatar
kj4cwa
Looks like any other truck any of us may have. That engine bay looks just like mine, just cleaner. I bet it even has that 2nd Gen lean. The pic of the roll pan looks like they tilted to the right a little more (as you all know our trucks lean to the left). Nice paint tho. I like RM_Indy's Indy better.
Old Jun 25, 2010 | 10:47 PM
CPTAFW163's Avatar
CPTAFW163
Where did you get that TB hat? I want to get one of those to make a functional ram air (Single tube). And what do they cost? Spectre sells them for 77 bucks for polished chromw, but i was wondering if they were any cheaper. Also is the hat offset (or do you need to bend threaded bar)?
Old Jun 25, 2010 | 11:09 PM
RamSport97's Avatar
RamSport97
I believe that TB hat came with his Pro Charger system.
kj4cwa- Not all of our trucks lean, you probably just need to replace your rear leaf springs.
Old Jun 25, 2010 | 11:11 PM
CPTAFW163's Avatar
CPTAFW163
yeah, those bad boys flaten when your truck sits. My truck sat for 12 months while i was deployed (my 1996) and the leaf springs were pretty flat. Also, the tires wobbled for the first 2 miles because they were temporarily indented in the position they sat in.
Old Jun 26, 2010 | 01:50 AM
jasonw's Avatar
jasonw
Site Moderator
My rear sides, measured to the top of the wheel well, are identical to within an eighth of an inch. My fronts, however, are off by 3/4 of an inch. Lean on driver's side. Front tires are same pressure. Coil spring on driver's side is OEM from dealership, less than 2 years old. Passenger side is factory original coil.
No one can tell its leaning except for me. I'm **** like that about certain things with the truck. I've learned to ignore it... for now. Plan on maybe eventually doing a 1" level kit, and only installing it on the driver side, to correct the slight front lean.
