My Build Sheet For Yal
Old Jun 29, 2010 | 02:15 PM
ryan0714's Avatar
ryan0714
Default My Build Sheet For Yal
Finally got it, so now u can see what im workin with, and also look at the suspension stuff and tell m does this mean i do have the HD 2500suspension? maybe this is why mine sits higher.
SX HD Vinyl 40/20/40 Bench Seat
-C3 Mist Gray
ADJ Heavy Duty Service Group
APAS Monotone Paint
A05P 5.2L Engine(ELF)/4Sp Auto Trans(DGT)
BAZP 136 Amp Alternator
BCQP 750 Amp Maintenance Free Battery
BGJS Pwr Disc/Drum Rr Anti-Lock Brakes
CBEP 40/20/40 Split Bench Seat
CGDS Front Height Adjust Shoulder Belts
CGWS Next Generation Front Air Bags**
CGZS Passenger Air Bag On/Off Switch
CKJS Black Vinyl Floor Covering
CSPS Passenger Assist Handle
CUVS Behind Seat Modular Storage System
CUYS Storage Tray
DGBS All 4-Speed Automatic Transmissions
DGT 4-Spd. Automatic 46RE Transmission
DHAP Lock-Up Torque Converter
DHKS Shift-on-the-Fly,231HD Transfer Case
DJCS 195MM Front Axle
DMH 3.92 Rear Axle Ratio
DRBP Corporate 9.25 LD Rear Axle
DSA Anti-Spin Differential Rear Axle
EAAC All Engines
EAGC All Gas Engine
ELF 5.2L V8 MPI Engine
GACS Tinted Glass Windows
GJDS Rear Fixed Window
GNAS Rear View Day/Night Mirror
GPUS Manual 6 x 9 Black Mirrors
GVAC All Vehicles W/O Power Mirrors
HAA Air Conditioning
HGBS Dash Liner Insulation
JAYS Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
KRXS STRIPE/BADGE/MOLDING/COLOR
KTXS STRIPE/BADGE/MOLDING/COLOR
LDAS Underhood Lamp
LMAS Halogen Headlamps
LPES Cargo Lamp
MBFS Bright Rear Bumper
MCTS Bright Front Bumper
MDAP Front License Plate Bracket
MFDS Bright Grille
MHAS Black Windshield Moldings
MWDS Removable Tailgate w/Caliper Latches
MXBS Front Air Dam
NAA Federal Emissions
NBKP EVAP Control System
NFWS 26 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NMCP Heavy Duty Engine Cooling
PW7A Bright White Clear Coat
QW7S Bright White Clear Coat
RAAC All Radio Equipped Vehicles
RASS AM/FM Cassette Radio
RCDP 4 Speakers
RDDP Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCBS 2-Spoke Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
TBBS Full Size Spare Tire
TBMP Tire Carrier Winch
TYX P245/75R16 BSW On/Off Road Tires
TZAP Goodyear Brand Tires
WDKS 16X6.5 Steel Wheels
WLBP Steel Spare Wheel
WLYC All Steel Wheels
WMCP Bright Wheel Trim Rings
WMJP Center Hub
XBSS Pickup Box
XCMS Vendor Painted Cargo Box
XEFP Transfer Case Skid Plate Shield
YAAS Build To U.S. Mkt. Specifications
YEP Manuf Statement of Origin
YGCA 7 Additional Gallons of Gas
ZERP Spring - Left Rear
ZHCP Spring - Left Front
ZTRP Spring - Right Rear
ZWBP Spring - Right Front
Z6AS GVW/Payload Rating
Old Jun 30, 2010 | 11:42 PM
03neonSE's Avatar
03neonSE
How did you get a build sheet? Interesting.
Old Jun 30, 2010 | 11:43 PM
redheadhunter21's Avatar
redheadhunter21
Just email dodge its free
