Herculiner interior floor?
Old Jul 5, 2010 | 10:02 PM
harlmolla001's Avatar
harlmolla001
Default Herculiner interior floor?
Anyone get rid of their old nasty carpet and coated the floor with herculiner or something like it? What does it look like? Ive been wanting to do it for awhile in my 95 ( the '06 has the vinyl work floor, as every truck should).
Old Jul 5, 2010 | 10:15 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Its going to be louder inside the cab. Other than that only thing I could think of is if you do a lot of wheeling get some floor drains to empty out the water.
Old Jul 5, 2010 | 10:28 PM
redheadhunter21's Avatar
redheadhunter21
My friend did it to his bronco, looks good since its a trail truck and cleans really easy, actually if you spray enough of it you can make it quieter in the cab, the bed coating stuff are good insulaters and do pretty good on sound deadening
Old Jul 6, 2010 | 12:41 AM
northernRAM's Avatar
northernRAM
i definetly wouldnt rule it right out, spraying the interior could have some rewarding properties to it if you wheel the **** out of your rig, as for a city truck, stick with the carpet or pre fabed vinyl flooring
Old Jul 6, 2010 | 07:24 AM
ryan0714's Avatar
ryan0714
mine came with the vinyl/rubber floors in it, and i love it. easy to clean,and its not super super loud inside the cab,and i run flowmaster 40 dumped off in-front of the axle.
Old Jul 6, 2010 | 07:46 AM
UnregisteredUser's Avatar
UnregisteredUser
I like my factory vinyl floors. They're wash 'n' wear and you can probably order up the kit for no more than a carpet kit, or maybe even less.
My worry about bedliner material on the cab floors is that any void at all is going to hold water and promote rust. Nobody needs a Flintstone-mobile!
Old Jul 6, 2010 | 12:44 PM
dakotas ram's Avatar
dakotas ram
theres a guy on here that did his whole truck, in and out in it....his name was motorbreath
Old Jul 6, 2010 | 01:33 PM
dodgeram07's Avatar
dodgeram07
Old Jul 6, 2010 | 05:07 PM
dakotas ram
i looked him up but didnt find his pics
Old Jul 6, 2010 | 05:16 PM
Augiedoggy's Avatar
Augiedoggy
i guy by my cabin did most his truck that way.... He didnt coat the inside so the truck continued to rot from underside out though....I did my rockers and the stuff has held up awesome for a year. But it is a bitch to keep clean and you have to use a stiff bristle brush as anything else hangs up on the aggregate (where the dirt also builds up between) and you have to keep amoralling it or it fades flat
