Tailgate.. closed for good..
x2 I had one of the little plastic clips break off from the handle that holds the linkage for the release... Just have to take the handle off the gate and pull both levers towards each other to get it open. You will probably find that you need another handle.
The rods which run out from the center pull handle to the latches on the ends of the tailgate may get stretched out if the latches siezes up. They have a Z in them about 1/2 way across and are not just straight pull rods. Had to rebend them on sons' 96. Solved the tailgate getting stuck closed that time.
Lunch is over, Back to work!
sprntpshr
sprntpshr
Did you ever get the tailgate fixed?
Hopefully its just the latch, my truck's tailgate ain't opened by itself in over a year.... I just pinch the two points together and open it. But when I put my chrome handles on I hope that is all the problem is
