Mopar Intake
Old Jul 15, 2010 | 04:41 PM
Annihilator_X9's Avatar
Annihilator_X9
Default Mopar Intake
Does anyone have any experience with this Mopar Intake?
http://www.summitracing.com/parts/DCC-5007790/
The Hughes kit is too much more my liking and I'm pretty sure my plenum gasket is blown because my 318 has a hard time hitting 55mph and up unless I'm on the gas pretty hard. She's also pretty hesitant with anything under 3-3500 range. I'm going to replace the PCV valve this weekend and check the plugs because I'm sure the PO hadn't.
Old Jul 15, 2010 | 05:21 PM
aim4squirrels's Avatar
aim4squirrels
That's an intake from really high running RPM's, probably not good for your towing needs.
That's an M1 4bbl single plane intake.
an M1 2bbl dual plane might be better if you can't afford the airgap. You can get one with egr and block that off if you can find one for cheaper.
I will say the design of the airgap is superior to all of those if you need low end torque. How often do you pull that boat around?
Old Jul 15, 2010 | 05:35 PM
Annihilator_X9
Thanks for the input. I pull it a couple of times a week.
Old Jul 15, 2010 | 05:41 PM
aim4squirrels
Then I think you would definitely hate that intake manifold.
Old Jul 15, 2010 | 05:51 PM
Annihilator_X9
So really for everyday use the Airgap will be a better buy then. I might just start with the Hughes Plenum kit in that case and maybe the Kegger mod.
Old Jul 15, 2010 | 08:32 PM
aim4squirrels
That will definitely be the cheapest route, and you'll get a little bump from shaving off the runners.
