2001 Dodge Ram 1500 Brake Issue
The other day while driving home as I was stopping for a red light, the break pedal sunk to the ground. As I was about to stop, it wouldn't and I slided thru the red light(Was 7am on a Sunday morn thank God). The brakes still worked, but, you had to press way down. The brake light stays illuminated as well now. I did notice when I got home that the brake fluid resovoir was completely empty/dry. Will just putting more brake fluid in take care of this problem or is there definitely a leak somewhere? I've not noticed any fluid on the ground.
This truck is not used that often...maybe once every two weeks.
There is most likely a leak somewhere, brake fluid doesn't really just disappear on its own. May be the master cylinder or who knows what else. Put some fluid in, have a helper push the pedal up and down constantly, and track where that stuff is coming out.
Let me move this to 2nd gen to help ya get some more answers.
^+1 on that location.
park that truck immediately and don't drive it till fixed.
to find the leak - put some more fluid in the master cylinder. park on pavement. pump the brakes several times. look for a puddle of fluid.
odds are good its the rear line on the drivers side.
do a search on brake line. (and break line LOL). you can buy a collection of standard lines of various lengths and assemble a replacement alongside the old one. no need to even remove the old one... you can buy an OEM replacement at the dealer and maybe summit, but it will be a lot more expesive than generic line at the parts store.
