Transmission fluid
Old Jul 22, 2010 | 04:39 PM
clarebear21's Avatar
clarebear21
Default Transmission fluid
I just had a friend replace my radiator yesterday in my 99 DodgeRam 1500. Now I have what looks to be like a transmission leak but the fluid is coming out somewhere near the back of the radiator. Is this something that I need to worry about or is it just fluid from the change for the radiator? I checked my tranny fluid and its at min.
Old Jul 22, 2010 | 04:55 PM
AF_HEMI's Avatar
AF_HEMI
are you sure its tranny fluid? it could be power steering fluid also
Either way, ATF+4 is REQUIRED for these trans. They're all exactly identical, so find the cheapest stuff you can. Walmart brand is the SAME stuff chemically as the high dollar stuff
Old Jul 22, 2010 | 07:18 PM
clarebear21
All i know is that it is red in color and it is kinda oily. And that it goes threw the radiator. and when we took out the old radiator there was the same thing running out of it.
Old Jul 22, 2010 | 07:39 PM
AF_HEMI's Avatar
AF_HEMI
which radiator? there are 4 up there. haha the biggest one is the engine coolant. right in front of that (real thin radiator) is the tranny cooler. in front of that and down low (short and fat) is the power steering cooler. to the right of all those is for the A/C.
The power steering fluid and tranny fluid look very very similar.
Old Jul 22, 2010 | 07:41 PM
AF_HEMI's Avatar
AF_HEMI
wow... disregard all that. this was originally posted in the 3rd gen so thats what i've been referring to. the 2nd gens could have an entirely different setup. doesnt change the fact that tranny and power steering fluid look the same though.
Old Jul 22, 2010 | 07:58 PM
dhvaughan's Avatar
dhvaughan
99 will have a transmission cooler built into the radiator, and then if you have the towing package, you could have a second, separate trans cooler. you won't have a ps cooler.
to replace your radiator, your friend would have had to remove the trans lines, and then reattach them to the new radiator. some fluid would spill out, maybe 1/2 quart or so.
do this - spray off the radiator, body, frame, etc and wash off all the fluid that's there now. try to get it all off, then monitor it for new leaks. if none, don't worry about it. if it does keep dripping, then you should fix it. you may have to remove the trans lines and wrap the threads in teflon tape or some other thread sealer. you could put a wrench on there to make sure they're tight, but don't overdo it and bend a line or anything.
check trans fluid only with engine running and in NEUTRAL, not park. don't let it get low and as said, use only ATF+4 fluid.
Old Jul 23, 2010 | 08:51 AM
young_blood's Avatar
young_blood
As stated above I would check the transmission cooler lines. If it is leaking transmission fluid from near the radiator this is probably what it is. Make sure they are connected good and tight
