does SCT/hemifever offer a speedometer correction ?
and if not - could he ?
i think its just a setting of the pinion factor.....
is this something you can do with a basic scanner, or what ?
somebody explain it to me.
I don't think he dose I know he can't do gear ration changes.
I used my superchips to fix my speedo.
I also found out that I didn't need to correct my speedo after my gear change.
Oh d if you need something to fix yr speedo give me I shout.
The SCT cannot do it.
They were working on that feature a while ago, but that was the last I heard.
The way our trucks are set up, nothing needs to be changed with the PCM for gear changes.
Some scanners can do that, but IIRC, it takes a pretty advanced one. Otherwise, if you have some spare $$$, the $tealer$hip can do it.
