late shifting 2nd to 3rd...adjustment??
Old Aug 9, 2010 | 02:15 PM
rwillie7926's Avatar
rwillie7926
Default late shifting 2nd to 3rd...adjustment??
1996 dodge 5.2 auto , shifts at high rpms from 2nd to 3rd, sometimes exceeds 50 mph before this happens.... Is this an adjustment to the throttle valve cable or a sensor replacement on the trans?
Old Aug 9, 2010 | 04:33 PM
tuski's Avatar
tuski
ya know thats a good question, i'm having the same problem. It started happening right after i removed the throttle body and put in a new IAC. fixed my idle problem, but now there's this shifting issue. I checked the throttle valve cable, didn't seem like anything was wrong.
Old Aug 9, 2010 | 06:45 PM
CappinHoff's Avatar
CappinHoff
http://bionicdodge.com/Download/Dodg...Adjustment.pdf
This will fix the issue. If it doesn't than it's an actuator or vacuum issue.
Old Aug 9, 2010 | 07:33 PM
rwillie7926
thanks cappin but your instructions seem wrong , "
For LATER, FIRMER shifts, slide the cable housing further OUT of (rearward) the locking
mechanism.
" , by moving the cable farther "out" that is actually forward, and vice-versa. Hope you can clear that up for me. thanks
Old Aug 9, 2010 | 08:26 PM
charlie1935's Avatar
charlie1935
My 96 did that at around 70,000 miles in cold weather, after 15 miles it it shifted normal.
One dealer said it needed rebuilt and one said maybe a flush would help but no guarantee. I had it flushed, filter changed and bands adjusted for around $200.00 and it has done just fine for 40,000 miles.
Now let the flaming start for flushing it!
Old Aug 9, 2010 | 08:31 PM
rwillie7926
trans was just rebuilt a month ago. new u-joints on the shaft, rebuilder already adjusted the tvc but still shifts late. not trusting him much, looking for a solution I can handle myself
Old Aug 9, 2010 | 10:17 PM
CappinHoff's Avatar
CappinHoff
mechanism.
It's not. I got that from montec in the tranny section.
Old Aug 10, 2010 | 09:52 AM
tuski's Avatar
tuski
oh man, i think this may be my problem. Cause i took that clip off and i think i may of broke it. so i guess that's more than just some stupid clip that holds the cable on there firmly.... thank you for showing this. i will take a look at it later today.
Old Aug 10, 2010 | 12:40 PM
tuski's Avatar
tuski
yo, so i adjusted the throttle valve cable, and I agree with rwillie, i slid the housing backwards, and it made the shifting more smooth and held the gears a shorter amount of time. I slid it back about 1/8" and i read on another forum saying that is what was default from the factory. Now it shifts smooth again and everything is running great. Thanks
Old Aug 15, 2010 | 07:19 PM
dodgeman2289's Avatar
dodgeman2289
ok i understand it but how do u make it pecise?? i dont want to do it and cause severe problems i added my hypertech programmer and with the plus 500 rpm it shift between 5500-5800 should i still do this adjustment?
