ac wont blow out vents need help
Old Aug 10, 2010 | 07:39 PM
blackedout00's Avatar
blackedout00
Default ac wont blow out vents need help
i have 2000 ram 5.9 2wd and have an ac problem.its 100+ degrees here and ac only blows throught defrost and floor when its on max a/c and if i switch to just vents it dont blow through the vents. if any one has suggestions im open cause its hot.
Old Aug 10, 2010 | 07:45 PM
VEETEN's Avatar
VEETEN
Use the search tool at the top and type in "wild vents"
many threads will pop up.
It's a vacuum leak, guaranteed.
Old Aug 10, 2010 | 09:24 PM
sk8erdude's Avatar
sk8erdude
go to autozone and get a HELP! check valve, its like 5 bucks. out it between your intake and where it Ys out. make sure you have it going the right way. your gonna have to find a way to seal it cause one side of the valve is to small to seal on the hose. i just fixed mine a few days ago....
