speedometer gear
Old Aug 14, 2010 | 01:01 PM
matty675's Avatar
matty675
Originally Posted by Scottr1110
hi awhile ago i changed my gears from 3.55s to 4.56s and from 265/75r16s to 37x12.5r17 so few years ago when i did that i did not know u could just change the speedo gear so i bought this stupid electric modulator to change the signal to the speedo and its never worked well the speedo changes depending on temp and voltage so i want to change the speedo gear and i can not seem to find a chart with the same numbers on it i find some with 35 teeth gears fit my application then i find other charts that say 32 teeth is for me so was just wondering where i can look i already bought a 35 tooth one and the speedo seems to read way to slow the factory gear is a 30 tooth and i got a spare 36 tooth laying around any advice would be great
need any advice in regards to puttn it on?
Old Aug 14, 2010 | 04:12 PM
Scottr1110's Avatar
Scottr1110
No I got it in fine just making sure I got the right tooth gear
Old Aug 14, 2010 | 08:15 PM
redheadhunter21's Avatar
redheadhunter21
Not to thread jack but i went from the stock 245/75/16's to 285/75/16's, could you tell me what tooth gear I have and which one I need to correct speedo, its not off far but my dad wants it corrected
Old Aug 14, 2010 | 09:45 PM
RM_Indy's Avatar
RM_Indy
245 were the stock wheels Id guess you would have a 33 tooth
Maybe 29 tooth speedo gear with the 33s(if 3.55 diff)
Guessing on both
BTW, thanks Scott, missed that.
While Id love to get rear disc I have to draw the line somewhere.
Old Aug 14, 2010 | 10:34 PM
Scottr1110's Avatar
Scottr1110
its easy to pull the speedo sensor to check the gear number the gear says what number it is its a 9/16ths bolt as i remember on the left side of the tail shaft of the tcase took me 5 min to change the gear out and indy didnt the last year of our style rams have optional disc brakes
Old Aug 14, 2010 | 11:29 PM
stands2p's Avatar
stands2p
Originally Posted by RM_Indy
My Indy came with 3.55grs stock & 275/60/17 tires on it & had 32 tooth speedo gear.
I swapped to 35 tooth speedo when i added 3.92grs.
Did your truck come with 265tires factory?
Makes sense having the 30 tooth gear for that 31.5" tall tire so the speedo would be accurate.
37" tires with 4.56 I thought worked out to 3.90 final.(used DML's tire calc)
35 tooth should be very close to accurate
http://www.dakota-truck.net/TIRECALC/tirecalc.html
knew someone would correct me.for the old tire size i used a 31" tire instead of a 31.6" tire.my bad and ty 4 correcting it.but i still come up with a 33 tooth gear.calculator is use.
http://www.tciauto.com/Pages/418/calculators.aspx
