oil presser gauge goes up and down
Old Aug 25, 2010 | 04:58 PM
BigRedRam95's Avatar
BigRedRam95
Default oil presser gauge goes up and down
Ok I don't know if you guys can help me or not but I am having some problems with my oil presser. I just changed the oil and filter I put full synthetic in it. Today I was watching my gauge and it is at about 35-38 psi idling and 40-45 at 1500 rpm but at idle it keeps going from 35 up to 40 then back down to 35-38 I took a video sorry its a cell phone video (Click on the pic to play the video)
Old Aug 25, 2010 | 07:28 PM
Raine883's Avatar
Raine883
Try a 180* t-stat, your oil is probably like water considering the temp of your truck.
Old Aug 25, 2010 | 07:30 PM
BigRedRam95
Its running at 200 on the dot that is what it has run from the first day I got it and the motor only had 67000 on it
Old Aug 25, 2010 | 08:12 PM
Hahns5.2's Avatar
Hahns5.2
200* is fine.
What oil filter are you using, I suspect it's the filter.
Old Aug 25, 2010 | 08:30 PM
BigRedRam95
I'm running a pruolator pure one the oversize one.
Old Aug 25, 2010 | 08:36 PM
BigRedRam95
One more thing I did not say when I went to the bigger filter I have put 6 quarts in this time its about 1/2 quart to full.
Old Aug 25, 2010 | 08:43 PM
PurplDodge's Avatar
PurplDodge
Sounds perfectly normal. You should see the oil pressure gauge on the S-10 fluctulate when you rev it up. It moves like a tach.
Old Aug 25, 2010 | 08:48 PM
BigRedRam95
Well you cant see it that good on the video but it will fluctulate at idle. I know it should go up when you rev it but is 35psi ok for idle?
Old Aug 25, 2010 | 08:50 PM
PurplDodge's Avatar
PurplDodge
Yeah, that is great. The only time you should worry is when it goes under 8 psi. The normal operating range is from 10 to 80 PSI. From the service manual.
Old Aug 25, 2010 | 08:51 PM
Hahns5.2's Avatar
Hahns5.2
35psi is plenty fine at idle, most engines idle closer to 20psi when warm in my experience.
The question is why it fluctuates, assuming your idle is steady.
