radio illumination bulbs?
Old Aug 26, 2010 | 01:53 AM
Scottr1110's Avatar
Scottr1110
Default radio illumination bulbs?
Does anyone know what the number of the really tiny illumination bulbs for inside the stock square radio are i cant find anyone that has them it bothers me that bulbs are burnt out i got the dash apart replaceing some other bulbs that are burnt out there about a 1/8 of a inch long there replaceable they twist out
Old Aug 26, 2010 | 02:43 AM
J415's Avatar
J415
Why not take this time to upgrade your stereo? I don't know the answer to your question, however, I'm sure they're not made because there isn't a market for them.
Old Aug 26, 2010 | 03:00 AM
CSCustomCars's Avatar
CSCustomCars
They are probably the gauge cluster bulbs. The ones that twist in/out. You'd have to take one to your local auto parts store and ask them. if not, compare them to twist bulbs for gauge clusters online. That is in the bulb doesn't come out of the socket. If the bulb comes out of the part that twists out, then it's probably a 194.
Got a picture of the bulb?
Old Aug 26, 2010 | 03:04 AM
Andrew2500's Avatar
Andrew2500
I had that problem and I just went on ebay and bought a new stock radio for $30. I'm a stock radio guy. Can't stand aftermarkets, so I know your pain.
Old Aug 26, 2010 | 07:39 PM
Scottr1110's Avatar
Scottr1110
I hate aftermarket radios look werid in the dash nothin matches. I have a amp and speakers tied into the stock radio. The bulbs twist in they are so small though if u put two keys together thats about how long and thick the bulbs are have alittle gray twist socket with a mistubushi badge on them.
Old Aug 26, 2010 | 10:00 PM
CSCustomCars
Like I said, I'd take one to Your local auto shop, or look around online for them.
Old Aug 27, 2010 | 01:06 AM
Scottr1110's Avatar
Scottr1110
been looking nobody around here has them i can find them but there like a 100 bulk of them only need 9 they are neo-wedge 3mm t-1s just dont know where to get them.
Old Aug 27, 2010 | 02:11 AM
CSCustomCars
You could go LED:
http://www.superbrightleds.com/cgi-b.../specs/NEO.htm
I also found this. Could probably get the bulbs at Radio shack.
http://www.toyota120.com/forum/showthread.php?t=3379
You might be able to find some here as well:
http://www.allelectronics.com/make-a...0/Lamps/1.html
Old Aug 27, 2010 | 11:59 AM
Scottr1110's Avatar
Scottr1110
Yea i found all of those the bulb has to be 3mm all those are 4mm or bigger the little 3mm are very rare it seems. Thanks for your help though
Old Aug 29, 2010 | 10:30 AM
ramit99's Avatar
ramit99
I repleaced some of mine. Got them at the Dodge dealer. Not that expensive. Same ones as in ther light switch and window swithes.
