Front Passenger side axle noise
Old Aug 26, 2010 | 10:19 AM
spitfireram's Avatar
spitfireram
Default Front Passenger side axle noise
I've been hearing a weird noise coming from my front passenger side tire. I thought it was a rock in the break...but wasn't. I jacked it up and removed the tire and didn't see anything. Then i spun the shaft and heard a clunking, rattle noise. Sounded like it was coming from inside the axle...It is 4x4...the noise speeds up as the truck does. I've been driving on it for a month now and it hasn't got any worse...
Any ideas...suggestions
Thanks
Old Aug 26, 2010 | 08:24 PM
wv ram's Avatar
wv ram
yeah there is a little plastic bushing in there thats part of the four wheel drive ,you need it and the innenner seal if i can find my paper i can give you the dodge factory part #s found a local dealer who sells a lot of 4x4s he carries in stock , if i remember it wasnt that much thinking less than #25.00 bucks hope that helps some
Old Aug 27, 2010 | 02:45 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Sounds like a bad ujoint or hub bearing.
Old Aug 27, 2010 | 02:58 PM
greenmachine's Avatar
greenmachine
How well did the hub spin? How long? If it is a hub bearing the hub will get significantly hotter than the other side.
Old Aug 27, 2010 | 05:14 PM
Agostage's Avatar
Agostage
Def sounds like u-joint
Old Aug 30, 2010 | 09:38 AM
spitfireram
WV Ram...what is the part number?
Thanks...I'll look into it soon
Old Aug 30, 2010 | 04:33 PM
zman17's Avatar
zman17
Dude! You need to check the ujoints.
Old Aug 30, 2010 | 06:02 PM
Sheriff420's Avatar
Sheriff420
Sound of a bad u joint ~> http://www.flickr.com/photos/29654534@N05/3556777493/
Old Sep 1, 2010 | 04:22 PM
spitfireram
Thanks...will do this weekend
