2001 Dodge 2500 truck Ball Joints
Old Aug 27, 2010 | 03:01 PM
corvet414320's Avatar
corvet414320
Default 2001 Dodge 2500 truck Ball Joints
I have a 2001 3/4 Dodge truck. I need to change the upper and lower ball joints and was concerned with the coil springs
Will I need to support the A-arms due to the coil spring pressure, or is there something else that I need to be concerned with? Thanks for any help.
Old Aug 27, 2010 | 07:49 PM
jasonw's Avatar
jasonw
Site Moderator
Hello, welcome to DF. I will move this over to the 2nd gen section, get you some help.
Old Aug 27, 2010 | 09:56 PM
Joshfinn's Avatar
Joshfinn
Check this out
https://dodgeforum.com/forum/dodge-c...placement.html
Old Aug 4, 2011 | 08:20 PM
DUSTY O'FERRALL's Avatar
DUSTY O'FERRALL
Don't touch the springs, to replace ball joints
Old Aug 4, 2011 | 08:53 PM
seabass202's Avatar
seabass202
If he/you have a two wheel drive, than yes the spring is a concern. use a floor jack or jack stand to insure the lower control arm doesn't drop enough to get a face full-o-spring.
Old Aug 6, 2011 | 08:28 PM
chrscott's Avatar
chrscott
If you had a 4x4, your biggest concern would be getting the bearing out of the knuckle... The only thing I have had to pay for so far.
