trailer brake wiring harness
Old Aug 31, 2010 | 03:33 PM
yellowbeast's Avatar
yellowbeast
Default trailer brake wiring harness
how do i tell if i have the harness for trailer brakes i just bought this truck it has the trailer electrical but im not sure about the brakes im needing to know if i just neet the brake unit itself if i already have the harness or everything any suggestions on how to find this out would be great
Old Aug 31, 2010 | 04:54 PM
Annihilator_X9's Avatar
Annihilator_X9
If it's a 4-wire then it's not going to control trailer brakes.
Annihilator_X9
Trailer Wiring FAQ
Old Aug 31, 2010 | 05:00 PM
PurplDodge's Avatar
PurplDodge
Does your truck have the factory 7-pole connector out back?
Old Aug 31, 2010 | 05:15 PM
yellowbeast
It has a 7 pole idk if its factory or not
Old Aug 31, 2010 | 05:45 PM
Cartalk2's Avatar
Cartalk2
98 maybe different from my 96 2500, but 96 was factory prewired with the 7 pin connector which included the brake wire. I just installed the brake control in the cab following the factory diagram -- all worked OK.
Old Sep 1, 2010 | 08:42 AM
atlrus's Avatar
atlrus
It's a 4-pin connector under the dash (often blue). Mine was cut off by some a$$hole down the road so I had to el-tape the 4 wires :{
This is a better guide for all situations: http://www.etrailer.com/faq-dbc.aspx
