360 heads on 408
Old Sep 1, 2010 | 08:32 AM
donizer's Avatar
donizer
Default 360 heads on 408
how many CC's are the heads on the 360? http://www.blueprintengines.com/popu...specs&pc_id=74 I'd like to bolt one of these up with some 360 heads and intake. Bigger TB while probably be needed. Just wondering if the top end parts from a 360 will bolt on? If so ill take 10 of em lol
Old Sep 1, 2010 | 09:19 AM
95RAM360's Avatar
95RAM360
make sure they are NEW heads, and not used, but i believe you could get away with it....if you're thinking of using used heads, think again, they tend to crack.
Old Sep 1, 2010 | 09:36 AM
donizer's Avatar
donizer
do you know the cc's of them? I was just gunne get a junk yard set. inspect them and deck them of course. I believe the 318 heads ar 58 CC and that would be a little bit too much comp for pump gas. If going new id spend my money on something a little better than stockers
Old Sep 1, 2010 | 10:01 AM
CPTAFW163's Avatar
CPTAFW163
you cannot use that block on our trucks. That is a LA engine bloick from the 70s/80s. We have Magnum engine blocks.
Sorry.
Old Sep 1, 2010 | 10:08 AM
donizer's Avatar
donizer
**** lol, anyone know where to get one of these in short block form? not heads or intake and what not. in magnum form, I assume getting one like that i could use my cap and rotor and accessories from my 318
Old Sep 1, 2010 | 10:10 AM
donizer's Avatar
donizer
http://jacksonautomachine.com/index....mart&Itemid=12 like this just cheaper lol
Old Sep 1, 2010 | 10:48 AM
CPTAFW163's Avatar
CPTAFW163
if you are on a budget...408 is NOT the way you want to go.
CHeapest: get the stroker kit yourself and put in the new crank rods and pistons. However, you don't sound like you can do that all by yourself. THere is a lot of machine work that needs to be done to do that. Hence why shortblocks are so expensive.
ALso, you boiught a DODGE MAGNUM. it is not like you bought a vortech chevy where there are parts out the wazoo on every website. These are the most expensive trucks to build up.
Wnat cheap, buy a 1997 chevy.
Old Sep 1, 2010 | 11:24 AM
donizer's Avatar
donizer
is there a right up on what all has to be done, or a how to for the stroker kit. machining isnt a problem, im majoring in it lol
Old Sep 1, 2010 | 11:27 AM
donizer's Avatar
donizer
is there a walk threw or how to on the stoker kit? what all has to be machined? thats not really a problem, im majoring in it lol
if its as simple as 1,2,3/pistons, rods, crank it wouldnt be bad at all. i think in pretty mechanically inclined, just never put a stroker kit in (just basic top end rebuilds...on old 351 clevelands)
Old Sep 1, 2010 | 02:14 PM
donizer's Avatar
donizer
nevermind, its not that simple, just read the hughes installation instructions
