radio and cab light not working
Old Sep 1, 2010 | 11:01 AM
RebelChewer's Avatar
RebelChewer
Default radio and cab light not working
Hey, the other day I had to change the hood brackets on my truck, and to take the hood off we cut the wire that attaches to the light underneath the hood. Well now my radio and the light in my cab wont work. We reconnected the wires and the fuses aren't blown. What could it be?
Thanks,
Jeremy
Old Sep 1, 2010 | 12:57 PM
Annihilator_X9's Avatar
Annihilator_X9
Did you check the I.O.D. fuse? Most people don't notice it.
Old Sep 1, 2010 | 11:02 PM
mrfarrell's Avatar
mrfarrell
definitely the i.o.d fuse...should of just unplugged the hoodlight take's 2 second's..
Old Sep 1, 2010 | 11:59 PM
Joshfinn's Avatar
Joshfinn
That IOD fuse is a real b!tch, i had similar problems. Pulled the fuse, put it back in and bam good to go...
Old Sep 2, 2010 | 12:18 AM
redheadhunter21's Avatar
redheadhunter21
No doubt IOD fuse like has been stated
Old Sep 2, 2010 | 01:35 AM
RebelChewer
Yea, it was the i.o.d fuse. Thanks guys.
Old Sep 2, 2010 | 01:44 AM
SplatSTi's Avatar
SplatSTi
hmm I dont have any lights under the hood or in the cab, maybe I should go look for this fuse.
Old Sep 2, 2010 | 09:12 AM
Annihilator_X9
Mine kept blowing due to a bad after market stereo install. The constant was exposed and grounding out. If you put one in and it instantly blows, check that. Otherwise it will be like a needle in a haystack.
Old Sep 2, 2010 | 11:19 AM
Maxx_Magnum's Avatar
Maxx_Magnum
you probably shorted something out when you cut those wires, if you didn't cut one at a time, they'll usually short for that brief second while the cutters are going through both them.... I can check my alldata diagrams to see what is all on that circuit....
Old Sep 2, 2010 | 11:42 AM
Maxx_Magnum
I PMed ya some wiring diagrams for the interior RebelChewer hope it helps!
