Need help!!! lost some top end
Old Sep 2, 2010 | 11:57 PM
281-318magnum's Avatar
281-318magnum
Unhappy Need help!!! lost some top end
Lost top end. Truck only does about 105-110 115 (on a good day) pedal to the floor. Don't know why? Need all the advise i can get.
Old Sep 3, 2010 | 12:27 AM
redheadhunter21's Avatar
redheadhunter21
I just want to know where there is no speed limit or its that high
But how long ago did you do wires and plugs, and next time go with the wind
Old Sep 3, 2010 | 12:30 AM
J415's Avatar
J415
Aren't our rams programed to go know higher then 110-115? Why are you going that fast to begin with?
Old Sep 3, 2010 | 12:55 AM
281-318magnum
Just speeding taking friend to hospital. Yea dumb could have killed us. The truck ran 120+ mph stocked. started having this problem when i installed the k&n cold air intake. so then i put the stock intak back any still nothing. so then i went and changed the plugs, wires, rotor cap, ignition coil and still nothing
Old Sep 3, 2010 | 01:29 AM
lastrights's Avatar
lastrights
your sig says no cat, that could be a BIG possibility, when i was running my longtubes with no cat , it sounded loud and sounded like it had *****, but then i put a cat on to pass emmisions and i was like where did all this power come from, and it was still loud !
Old Sep 3, 2010 | 01:44 AM
J415's Avatar
J415
I hear what your saying. Hope your friend made it okay. In regards to the question at hand, I don't think your planning on going that fast again so I wouldn't even worry about it.
Old Sep 3, 2010 | 01:52 AM
redheadhunter21
I got no cat and can easily hit 110, doing this on roads between farms so if I f^ck up its just me, getting from there to 120 becomes hard(think brick and no aero) but it makes it, this was on my old tires though 245/75/16's but I do have the 5.9
Old Sep 3, 2010 | 03:48 AM
dhvaughan's Avatar
dhvaughan
seems like there is a top speed limiter of 112 at stock pcm setting. this is adjustable via a scanner or superchips. i suspect your variation has to do with perceived speed, as determined by the speed sensors, tire size, speedo calibration, etc.
if you want to go faster, increase top speed limiter with superchips or hypertech.
Old Sep 3, 2010 | 04:46 AM
UnregisteredUser's Avatar
UnregisteredUser
No living things should be anywhere near when you discover that directional control is just an illusion at 120MPH in a full-size pickup without extensive suspension modification.
That said, the PCM has a programmable speed limiter in it.
Old Sep 3, 2010 | 09:00 AM
nocturnalsst's Avatar
nocturnalsst
If you ignore the fact that it takes a couple football fields to stop from going 100+, it feels pretty safe in these trucks. Long as roads are nice and strait, and nothing happens that would make you swerve they handle it fine. 120 is where i start questioning how fast i really want all my driveline components spinning
Stock speed limiter was 117 in my truck. past tense.
