switch firing order of 7 and 8
Old Sep 9, 2010 | 11:34 PM
donizer's Avatar
donizer
Default switch firing order of 7 and 8
Ok i had a header gasket leave. went to fix it today, unplugged the plug wires on the pass side, got 5 right, 6 was loose, and had codes for a random misfire, and a misfire on 6 and 8. fixed 6 then figured 8 and 7 were close in firing order so they would hit a, just a little off, so i switched them. maybe its just cause i never got into it with the exhaust leak cause it sounded like chit. now it seems like it has a lot more nut!
any ideas? or is it in my head?
Old Sep 9, 2010 | 11:52 PM
CPTAFW163's Avatar
CPTAFW163
you will do serious damage to your motor if you keep it like that.
There is a reason why things are balanced.
Oh, and it sounds like it had more nut because it is working against the grain.
Old Sep 10, 2010 | 10:41 AM
donizer's Avatar
donizer
would it run if i switched 7 and 8? Im not exactly sure if i did though? It idles and runs great
Old Sep 10, 2010 | 10:49 AM
Arachnyd's Avatar
Arachnyd
I hate to ask it, but was it wrong before???
I bought a used car that wouldnt run properly only to discover the previous owner had replaced the spark plugs and two were out of order...
Old Sep 10, 2010 | 11:00 AM
donizer's Avatar
donizer
the header gasket was half blown out, and with my pacesetters you cant get s socket on a couple of the header bolts, and its easier to unplug the sp wires to use a box end wrench.
Old Sep 13, 2010 | 03:09 AM
CPTAFW163's Avatar
CPTAFW163
Pop your hood with the engine idling. If there is a slight hiccup every 3 seconds...a plug is out of order.
Trust me, it does not have more "nut." Buy a manual and fix your firing order
