red and black wire from front axle to transfer case
Old Sep 13, 2010 | 11:05 PM
bobracing32's Avatar
bobracing32
Default red and black wire from front axle to transfer case
what do these lines do. i noticed the red wire/tube is broke is it good bad or to be fixed or how to fix it
Old Sep 13, 2010 | 11:25 PM
Sheriff420's Avatar
Sheriff420
Those are vacuum lines that control the shift motor in the front axle. When they are damaged or disconnected then you have no 4x4.
I have some picture of how they hook up on the transfer case if you need them.
Old Sep 13, 2010 | 11:28 PM
bobracing32
it looks like theres a piece of shrink wrap over where its broke.? i can slide it right back in but im afraid it will fall out again
Old Sep 13, 2010 | 11:33 PM
Sheriff420's Avatar
Sheriff420
You can get universal rubber vacuum tubing at the parts store that will fit over the line that is broken. Get some of that then slip it on the broken section and use some RTV to stick it to the broken line. It wouldn't hurt to slather some RTV over the outside of the patch to make sure it won't leak. Just don't get any of the sealant inside the tube or again, no 4x4.
