Truck out of alignment
Old Sep 15, 2010 | 11:24 PM
CPTAFW163's Avatar
CPTAFW163
Default Truck out of alignment
Well, just noticed that my tires are worn a bit more on the OUTSIDE of the treads.
It is visually noticeable.
Would that be the reason why my truck seems to pull?
When you couple in that with the 3 inches of play in the steering (from the factory) it makes for some overcompensation/undercompensation and general nervousness when driving.
It doesn';t seem bad all the time though.
ALso, would that have an effect on how the truck handles when braking? It seems that when I brake HARD, it pulls to both sides (or maybe one side, and I overcompensate).
I think I need to get an alignment. GMC dealerships around here have them for 49 bucks. i think i will take them up on that offer.
--Dan
Old Sep 15, 2010 | 11:27 PM
Pacmanloads's Avatar
Pacmanloads
That $49 is gonna turn into a lot more $. I had the same problem and I ended up replacing most of the worn out front end. Wheel Bearings , ball joints ...ect.
Old Sep 15, 2010 | 11:28 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Wouldn't wear on the outside be either positive camber or too much toe in?
Just curious, how can it pull to both sides? Wouldn't that just equal out?
Old Sep 15, 2010 | 11:58 PM
Scottr1110's Avatar
Scottr1110
probally got some bad parts im a alingment tech bet you got the ball joint in the tie rod in the middle bad or one of them can jack it up shake the wheels side to side if u got play u will see it then shake up and down that will check ur ball joints and wheel bearings side to side will check ur steering linkage.
