Who is the rebuild guru on this board? - questions...torque build
Old Sep 19, 2010 | 11:54 AM
littletunny's Avatar
littletunny
Default Who is the rebuild guru on this board? - questions...torque build
1999 Dodge Ram 4x4 5.9L (120K miles)
So here is the deal. I did a compression test yesterday. All cylinders around 150 psi which means I dont have to yank the motor.
I need more torque. The motor feels a little weak. It could be the plenum gasket so I am going to replace it.
I have an oil leak so I am going to replace the rear seal and oil pan gasket. I am going to follow the instructions on Pavement Sucks website.
So that gets me a new plenum and stops the oil leak.
Now, what is a good start to getting more low end torque that can be done in the body without pulling the motor.
I need more torque BELOW 3000 RPM.
This truck is used for towing. I dont care about improvements above 3000 rpm.
I already have dual exhaust.
Whacha think????
Old Sep 19, 2010 | 12:10 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Fastman TB, 1.7 HS roller rockers, SC or SCT tuner, and any gears besides the 3:55's you most likely have.
Old Sep 19, 2010 | 12:28 PM
dhvaughan's Avatar
dhvaughan
low rpm torque from 5.2/5.9 is wimpy.
as zman said, you'll need a GEARS, maybe an RV rated cam with tune, and GEARS.
lets see, what else - oh yeah, you'll need 4.10 or 4.56 GEARS.
Old Sep 19, 2010 | 12:58 PM
zman17's Avatar
zman17
Oh yea! Did I mention gears? LOL And some people think I have NO sense of humor.
Old Sep 19, 2010 | 01:19 PM
Hahns5.2's Avatar
Hahns5.2
I remember seeing dyno numbers from the KRC "RV" cam and it made very impressive torque numbers, a cam and gears is really the way to go when you need to boost low end grunt, a tune doesn't hurt either.
Here's the dyno results http://www.dakota-durango.com/forum/...4&postcount=15
Old Sep 19, 2010 | 06:25 PM
CPTAFW163's Avatar
CPTAFW163
Beat me to it Hans.
http://www.bionicdodge.com/bionic/in...p?topic=9197.0
that is the whole thread.
KRC is no longer in business, but look for a cam with those specs and get 1.6 roller rockers, underdrive pulleys, EQ heads v 2.02 valves, and a 14x3 air filter. You will actually get better HP with the EQ heads. They used stock R/T Heads.
If you don't want to try a camshaft, just get 1.7 Roller rockers and heads.
--Dan
Old Sep 19, 2010 | 09:48 PM
iwhitne's Avatar
iwhitne
I've got the HS 1.7's Fastman and tuner.. low end torque was greatly improved.. I have 3.55's.. 4.10 would give me some sick torque numbers
Old Sep 19, 2010 | 10:07 PM
dodgeram07's Avatar
dodgeram07
Whacha think????
the size? cat back ?
to big u can lose bottom end
Old Sep 19, 2010 | 10:44 PM
BlueBeast2's Avatar
BlueBeast2
KRC sold out but is still in business.
Zman how are ya?
Old Sep 19, 2010 | 11:38 PM
redheadhunter21's Avatar
redheadhunter21
Its watson performance egineering now same place just new owner and name, I would contact Sean aka hemifever about SCT for your truck and you might want to ask him about the RV cam too if that sounds like a good idea to you
