quick question about tuning-
Old Sep 19, 2010 | 05:06 PM
drewactual's Avatar
drewactual
Default quick question about tuning-
How long does it take generally for the computer make adjustments for changes?
I just finished the H&S RR's, Hughes Plenum Kit, and 180* stat.. I went ahead and flushed the cooling system changed oil/filter, plus wires/plugs/cap/rotor..
Everything is back together as it should be, and there are no leaks. She is running sluggish.. but no codes have popped up as of yet. I kinda figured the computer needed some time to make adjustments, but I've no idea how long that is going to take.. thoughts?
Old Sep 19, 2010 | 05:32 PM
UnregisteredUser's Avatar
UnregisteredUser
If you haven't or can't do a prescribed "OBD-II Drive Cycle" it can take as long as 200 miles or so after resetting the PCM for it to get fully aware and accustomed to the new reality.
Old Sep 19, 2010 | 05:58 PM
drewactual's Avatar
drewactual
wow..
I ordered a SCT from Hughes (shoulda went through hemifever I've since learned) and it isn't here yet.. It should be this week.. it's going to be interesting to see which happens first- the self adjust, or the tuner... huh..
Sheriff420's Avatar
Sheriff420
Anywhere from 20-200 miles but normally 20-30.
Old Sep 19, 2010 | 06:19 PM
CPTAFW163's Avatar
CPTAFW163
the self adjust will not get near where the tuner will get you.
Old Sep 19, 2010 | 07:50 PM
drewactual's Avatar
drewactual
weird stat issues now... seems it doesn't want to open... dangit...
