Oil Pressure
Old Sep 29, 2010 | 10:42 PM
charlie1935's Avatar
charlie1935
The sending unit is at the back of the motor on the passenger side of the distributor.
A drop in pressure when is normal.
Old Sep 30, 2010 | 02:26 AM
bigslick050's Avatar
bigslick050
Use a special SU 1 1/16 socket to pull. Most deep sockets won't fit..
Oil pump is not too bad..change the pan gasket and clean out the screen while your in there. 3-4 hr job
Old Sep 30, 2010 | 11:02 AM
yzinger's Avatar
yzinger
is it fair to say that if my oil pump was going it would not drop to Zero...then come back up...or, do you all think it is my oil pump? -Anyway to rule one out?
Old Sep 30, 2010 | 01:41 PM
cmckenna's Avatar
cmckenna
Brad,
I would rap on the sending unit to verify a change in the reading. Like I had stated earlier, mine was dropping out to zero as well and, it would bump up to 30, back down, up 50, back down to 20 etc.
All it may be is a fault / stuck sensor. Get a 1/2 Allen wrench and rap on it along with removing the connector and placing it back on. Then, move the wires right at the connector body where they exit. Make them straight up and down vs. being bent over at a right angle /over the side of the connector. Get back in, and fire it up and retest.
If the issue subsides, it's the sending unit. Try that first.
CM
Old Sep 30, 2010 | 01:45 PM
yzinger's Avatar
yzinger
Thanks very much for the words. Man, i feel so loserish (sp) as I am building a 400 poncho for my Trans Am, yet, cannot locate this goddamn sending unit! - Point being, I am very mechanical, my, i will remove the air lid and stuff..
Thanks again
B
Old Sep 30, 2010 | 02:18 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Yes, remove the air hat.
Old Sep 30, 2010 | 02:34 PM
cmckenna's Avatar
cmckenna
Thanks again
B
Hey, no sweat Brad. You'll find it once you remove the air-intake assy. It's on the pass side of the Dizzy right at the very back of the block. May have to either lay on the engine and peer over the TB or, you can crouch in the pass side engine bay and look to the pass side of the dizzy.
CM
Old Sep 30, 2010 | 05:33 PM
zman17's Avatar
zman17
If you look at his link, it will give you a good idea of where the oil pressure sensor is.http://dodgeram.info/tsb/1998/18-48-98/18-48-98-v8.htm
Old Sep 30, 2010 | 07:37 PM
dodgeman52's Avatar
dodgeman52
u might want to run a mechainl guage so u can get a true idea on whats going on
