7 Codes
I had my 96 ram 5.2l in the shop to get a bearing changed on it and my check engine light had been on for a bit so my mechanic hook it up to the diagnostic cause ive been having problems with the overdrive (NO OVERDRIVE)had a motor put in it recently.
So hooked it up and 7 different codes came up as listed.
PO743-Torque Converter Clutch
Solenoid Circuit Electrical
PO753-Shift Solenoid A Electrical
PO713-Trany Fluid Temp Sensor Circuit
High Input
P1757-Undefined Code
PO711-Trany Fluid Temp Sensor Circuit
Range/Performance
P1762-Undefined Code
PO748-Trany Fluid Pressure Control Solenoid Elec.
Now im just looking for sum feedback as to which sensors go with each ones and would this be a factor as to why i have no Overdrive?
thx
High Input
Range/Performance
thx
