a couple more questions
Old Oct 3, 2010 | 02:33 PM
yellowbeast's Avatar
yellowbeast
Default a couple more questions
sorry about so many questions but im trying to learn as much as i can about our trucks i have a 99 1500 4x4 with the 318 in it and i was wondering how to tell what kind of transmission it has in it i was told that it was rebuilt when i bought the truck and what types of mods will give me better pulling power? thanks to all you smart truck people out there
Old Oct 3, 2010 | 03:33 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You have a 46RE trans. That's all they have in them unless it diesel or a v10.
Old Oct 3, 2010 | 05:18 PM
95RAM360's Avatar
95RAM360
best mod to start with is the Plenum....
Old Oct 3, 2010 | 06:27 PM
slider15004x4's Avatar
slider15004x4
I here a lot on here about the plenum, but what benefits does it give you, other than if you replaced it because it was blown?
Old Oct 3, 2010 | 06:31 PM
zman17's Avatar
zman17
You just answered your own question!
Old Oct 3, 2010 | 06:32 PM
95RAM360's Avatar
95RAM360
everyone's plenum will blow out, you cant just replace gasket...you need a kit from hughes engines or APS Precision
i went from getting around 8-9 mpgs to a good 12-14 mpgs city. but i gave it a tune up as well...
and i can go from my house, to my parents house (283 miles) on less than a half a tank (i have 26 gal.) and thats all highway....
and it will run alot better, your cat has less of a risk to get clogged, you wont have much oil consumption, and yopur plugs have less of a chance to get fouled....
plenum leads to more problems.
Old Oct 3, 2010 | 06:35 PM
slider15004x4
Is there a way to tell if yours is blown or is just best to replace it no matter what?
Old Oct 3, 2010 | 06:41 PM
zman17's Avatar
zman17
Actually! I read his ? again. If it's NOT blown, replacing it will give you no gains. It's not a mod.
Old Oct 3, 2010 | 06:45 PM
atlrus's Avatar
atlrus
The best mod will be to trade it for a heavy duty 2500 Seriously, the 318 has less towing power than my SUV, although good enough for a boat or a pop-up. Most mods I've seen here are either for MPG or for HP, not torque and I doubt there is much you can do to raise the towing capacity.
Old Oct 3, 2010 | 06:46 PM
zman17's Avatar
zman17
If it aint broke don't fix it! LOL here is a test you can do http://dodgeram.info/tsb/2000/09-05-00.htm. I would rather pull the TB and look inside the intake with a mirror and flashlight for oil pooling. I've had them check out fine using the factory TSB I provided, only to pull the intake and see the gasket hanging out the side of the plate. I suggest you do a search here for "plenum". Read up, and go from there.
