why are there 2 seals in quad4x4 kit?
Old Oct 7, 2010 | 04:05 PM
matty675's Avatar
matty675
Default why are there 2 seals in quad4x4 kit?
i purchased the right side quad 4x4 axle seal kit and it came with two seals identical in appearance. is one just an extra or what?
Old Oct 7, 2010 | 04:16 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Yes, so when you F up the first one you have another! LOL
Old Oct 7, 2010 | 04:19 PM
matty675's Avatar
matty675
haha ill just have to hope 2 is all i need! what size is the hub nut with the cotter pin?
Old Oct 7, 2010 | 04:26 PM
zman17's Avatar
zman17
Old Oct 7, 2010 | 04:38 PM
matty675's Avatar
matty675
damn thats big, will it only come in 3/4 drive?
Old Oct 7, 2010 | 04:43 PM
zman17's Avatar
zman17
No, 1/2" will be most common. But 3/4" would be a lot better. You better start soaking the nut now. You will also need a 14mm 12 point impact socket and a torque wrench capable of atleast 175lbs.
Old Oct 7, 2010 | 04:55 PM
matty675's Avatar
matty675
the nut was just removed in january so it shouldnt be seized or anything, right? is the best approach to removing the hub assembly- loosen up the bolts a bit and hit them with a dead blow till it breaks loose?
Old Oct 7, 2010 | 05:03 PM
zman17's Avatar
zman17
I wouldn't hit the factory bolts, buy a couple regular bolts to hit, or get a cheap socket along with the good one, and use the crappy one to beat on. Why was the big nut removed? If the bearing is fairly new and antiseize was used, it should come out pretty easy.
Old Oct 7, 2010 | 05:27 PM
matty675's Avatar
matty675
to replace the axle seal, but it still leaked. whats the cheap socket for?
Old Oct 7, 2010 | 05:32 PM
zman17's Avatar
zman17
To put on the factory bolt so you can beat on it ,instead the factory bolt head, if you can't find some cheap bolts to screw in and beat on.
