stalling problem
Old Oct 14, 2010 | 11:43 AM
plasman's Avatar
plasman
Default stalling problem
I have a 1996 dodge ram 1500 2 wheel drive 318 gas. The truck stalls several times for about the first ten minutes of driving. A after that it runs good. Diagnostic test has no codes. Any ideas?
Thanks
Old Oct 15, 2010 | 07:04 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Thanks
Try replacing the precat o2 sensor.
Old Oct 15, 2010 | 10:08 PM
CSXfan's Avatar
CSXfan
May be a battery problem too. If your truck has one, check that the voltmeter on the dash is reading right around 14. If that's normal then check your battery terminals. Make sure there is no corrosion on the battery posts and that the terminals on on tight.
