Stumped both parts stores in my town
Old Oct 20, 2010 | 04:53 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Make sure the new tensioner pulley has the same amount of grooves as the other existing/stock pulleys. Also check that the belt has the correct amount of grooves. There are 6 and 7 groove pulleys and belts, depending on year.
Old Oct 22, 2010 | 02:30 PM
squarebit's Avatar
squarebit
It's your water pump. I shredded 2 belts before I realized this, then the pump seized.
If you haven't changed it in a while, it's almost a sure thing.
Old Oct 24, 2010 | 08:26 PM
CKGOSS35's Avatar
CKGOSS35
Had the same problem as you. Tried tensioner and idler pulley. Even checked the water pump and that felt ok. One weak later water pump pulley let go and almost came out of the pump. I had checked it not a day before. The bearing was wasted and was moving in the pump housing. The truck didn't leak until it let go.
