ABS problem, No ABS light...
New guy here,
I have a 2001 3500 4x4 automatic with RWAL brakes. A few months ago the anti locks started acting funny. When I'm slowing down and get below 10mph the ABS motor runs (or the dump valve opens) causing the pedal to go soft and then releasing the brakes briefly. It seems like once the pressure drops enough then the brakes begin to work fine again. Again, no ABS or check engine lights. It will also act the same if I'm backing up. The problem is consistent it does it EVERY time I'm stopping. At speeds above 10 mph the brakes work normally.
Any help would be appreciated.
Welcome to Dodge Forum.
I will move this to the 2nd gen Ram section (1994-2002 for 3500s), get you some answers. If I were you, I'd also post this question in the diesel section since you have a 3500.
