Starting issues
Old Oct 21, 2010 | 12:11 AM
Jedi28's Avatar
Jedi28
Default Starting issues
I bought this truck used. It's a 2001 Dodge 5.2L Quad cab 1500series. 2wd.
It clicks when starting. I changed batteries out from my other truck and it just clicks away. What gives? I am new to these dodge trucks.
Old Oct 21, 2010 | 12:29 AM
lennemann23's Avatar
lennemann23
Take the starter out and take it to your local auto part's store and have them test it in their machine.
Old Oct 21, 2010 | 10:20 PM
PatriotBSU's Avatar
PatriotBSU
I had this problem a couple weeks back. If you turn the ignition, and it only gives one click, replace the starter. It will cost around $75 after core return. I changed mine out and now everything works great, no problems starting up.
Old Oct 21, 2010 | 10:31 PM
lennemann23
Lmao at the above post. If I were you which I'm not, but if I were before I spent any money on a new starter I would take the old one out and have your local auto part's store test it. Why spend the money before you know if it's good or bad? Could just be a loose ground.
Old Oct 22, 2010 | 08:30 AM
charlie1935's Avatar
charlie1935
First check cable connections at battery, starter, and all grounds.
