97 5.9 No acceleration
Old Oct 23, 2010 | 04:54 AM
docferg's Avatar
docferg
Default 97 5.9 No acceleration
Truck starts fine and idles fine but when I try to accelerate it stubles and surges
Old Oct 23, 2010 | 04:58 AM
UnregisteredUser's Avatar
UnregisteredUser
Could be many things, but first I'd want to check that catalytic converter.
Remove the pre-cat oxygen sensor(s) and take it for a spin. If it improves, you've got a bad catalytic converter. You can't drive around with the sensor(s) out, so if you determine that you've got a failed cat, replace it straight away.
If that's not it, try to gather more information about the failure and come on back.
Old Oct 23, 2010 | 05:29 AM
docferg's Avatar
docferg
Brand new cat
Old Oct 23, 2010 | 08:32 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Check the fuel pressure with a gauge. Was the o2 sensor replaced when the cat was? Does the cruise control work and do you have any issue's with your heater controls?
